I have only had the car for only 5 months and it was running fine and then one day i turned it off from using it for the day and came out the next morning to use it and it wouldn't start. The engine is turn but it seems there is no spark at all i went to my nearest sprints and asked there help and bought a coil, plugs, leads, dizzy cap, rotor button and then put the parts in and noticed while doing this the end spark plug had oil on it and inside the lead :/ and after replacing all of these parts it's still not starting and just sitting there. i have also noticed the fuse box under the hood is also melted but fuse's are ok. Has anyone else had this problem and/or could have any idea what is going on and what i need to do, i reckon i was sold a lemon and ripped off, i'm a single mum of 3 boys and badly need this VL running for school runs and shopping. Hope someone can help...
Sounds like worn piston rings / cylinder walls, when they get extremely worn over time because of general use or bad servicing, oil can seep past and make its way into The combustion section and onto the spark plugs. The fact that it's in ur lead makes me think the plug wasn't in tight enough as you can't exactly push oil thru the middle of a spark plug into the lead
See if your getting fuel pressure. Could be crank angle sensor Could be a faulty fuel pump, fuel pressure reg, coolant temp sensor. I wouldn't be jumping straight away at the motor being stuffed.
i know fuel is getting though coz when i turn it over you can smell the fuel and fuel pump is a good one. But i might think about the crank angle sensor...
It will be the crank angle sensor. It's common on the rb30. It's inside the dizzy. Refur to my thread below in my sig to change one. As u said u got a dizzy cap but not a cas
I second that. I was on the way home from work one arvo an my car just died on me, took ages to get it started, and then the next day on the way to work it did it again, so I got a CAS off eBay which came with the bearing too, and threw that in and wham bam thank you ma'am it was sorted. Even if it doesn't fix it, it's good to change the CAS anyway since they're one of the many parts which are rooted on pretty much any VL.
The wires that go to the crank angle sensor can break where they go into the back of the plug, so check that too. I would say its a crank angle sensor problem.
OP hasn't been back since she first posted. Single Mum, Hackham West, say no more. (Those playing at home will understand.....)
My first vl did something like this while driving i changed everything and it turned out the timing belt stripped a few teeth and was f**K*D and spun on the cam gear and yeah thats bad if that happends you may aswell get a new motor. check your timing belt.
Considering she needed the car running for school runs and shopping, she's either sold the car, had it fixed by a mechanic, or the kids have dropped out and now work in the shops where she gets her shopping so that they get the perk of free delivery to their house, hence not needing to fix the car.
