please help me understand this
prjacksonau
62
vn ss
hi me an my son both have a vn commodore ss we both have worked motors built by the same bloke except mine has a lot more head work done.
well my queeston is why does my sons car at take off nearly launch me through the rear window an mine is not much more than standard.
can give more specs if sumbody is willing 2 answer this for me
p.s. no we have not have them on the dyno yet.
Doctor Bob
Grandpa
Retired
RG. Colorado & Caravan
if the heads have been ported heaps more as you have said they may be too big loosing low end torque & need lots of revs to work.
Rob
FXST01
The Grey Man
Perth, WA
VP V6 Exec
Do they both have the same gearbox/diff?
prjacksonau
62
vn ss
yeh same gearbox an diff in both. sons heads where "quote engene builder" just cleaned up not much above standard mine where ported an shaved rated 2 530hp. any1 got any ideas on how 2 get the same low end power as my sons short of a head change.
sir355
Father Figure
Cairns
VR SENATOR 215, HZ ute
put a stroker crank in it!!, but is more than short of a head change
prjacksonau
62
vn ss
maybe a ratio change in the diff any1 got any ideas
RVN 355
35
WEST SUBS
91 VN SS 355
Tune ECU re programmed to suit all ur mods,timing adjustments,diff gears, compression change
sir355
Father Figure
Cairns
go 3.9. easy swap, Are you running the auto or manual?
Have you had your car dyno tuned since all the mods?
prjacksonau
62
vn ss
nah havent had time 2 get em dynoed yet they are both auto
sir355
Father Figure
Cairns
mate, there is your problem. Your computer is not tuned to your mods. The tune in your sons is closer as the heads are not flowing as much.
You can't go and do mods to a car and not match your chip to them and hope it is going to go well. Dont buy an off the shelf chip either. Get it dynoed real time by a pro. The difference will be huge!!
Good luck, hope my son enjoys his first car in 17 years!!
