xkyle22x
Hey guys, today I swapped the stock shifter on my vz thunder Ute for a cube speed t56 shifter. Looks the goods, seems identical to the rip shifter. Really happy with it. Everything went smoothly installing it and feels great. Shifts perfect feels tight, everything was fine.
I drove it around a bit through every gear and reverse no worries then later tonight I went out 5 min drive and reverse parked it but when I went home and went to reverse park at home it won’t go into reverse it’s like it won’t even select the reverse gate.
I would assume it’s something to do with the shifter but I don’t know what it could be. Everything was fine after install.
I’ll add I did have to drop the trans down a bit to get the front shifter bolts in so maybe I pinched a wire or something?? Not sure if there is anything electrical it could be just a thought.
Any help would be appreciated. Thanks in advance.
