Agey20psi
- Sep 7, 2019
- 29
- 0
- 1
- Age
- 42
- Location
- Adelaide
- Vx commodore l67 supercharged v6
Hey I own a Vx Calais v6 L67 supercharged.. the car has gone from running rough,stalling on idle ,up and down revs while idling,stalling while driving so I have changed #crankangle sensor,tps sensor,idle sensor,new fuel pump,new spark plugs,new leads,new coils,new fuel pump module,new air flow,new injectors,new fuel pressure reg,
now after all them new parts it won’t even start now or not even turn over ,so I changed the relays checked fuses changed ecu and bcm (paired ) still won’t crank over or the fuel pump doesn’t com on either when I turn ignition on I get dash lights but that’s it can’t fault code check cause it won’t let me Please help
