Please HELP
Max.boost
42
Vx V6 supercharged commodore
I have got no communication with pcm were n wat wires should I be looking for
_R_J_K_
Zenki S14
Need more info. Symptoms? What are you trying to do and what have you already done?
Max.boost
42
Tech 2 won’t communicate to ecu keeps telling me check connectors
Trevor loves holden.
vs commodore
Here u go..
lout
60
Langwarrin Victoria
is the car running
tech 2 connects to the bcm which then connects to ecu
Utel67
Tasmania
Vs s3 ute
Your information says you have a vx l67, have you tried bridging the 5&6 pin on the obd port and counting the flashes.
ant797
bunbury
vy s
reckon if he has a tech 2 he would want that to work
vs commodore
Just check the F29 fuse it powers the tool, Click the file to understand which wire/pin is for.
BlackVXGTS
Melbourne, SE
1. Are you using a genuine Tech2 or a Chinese clone or something else?
2. Describe in detail on a step by step basis how you are attaching the device to your car, particularly the type of connector you are using. Provide a picture of the connector if you can.
3. Describe what (if anything) you have input to Tech2, and what replies you have received from Tech2 up to the time you get the error message.
4. Refer to the attached file for further information:
  • Chart A V6 PCM On-board Diagnostic System Check.pdf
