Yeh I tried it doesn’t do it anymore it used to and use to start but not anymoreYour information says you have a vx l67, have you tried bridging the 5&6 pin on the obd port and counting the flashes.
Na car is not running no crank no fuel pump no pulse it won’t let me communicate to ecuis the car running
tech 2 connects to the bcm which then connects to ecu
Hey do u no why I can’t bridge 5/6 pin anymore the engine light will not flash1. Are you using a genuine Tech2 or a Chinese clone or something else?
2. Describe in detail on a step by step basis how you are attaching the device to your car, particularly the type of connector you are using. Provide a picture of the connector if you can.
3. Describe what (if anything) you have input to Tech2, and what replies you have received from Tech2 up to the time you get the error message.
4. Refer to the attached file for further information:
Yeh then most go out then trac off light comes on by its self n I can’t turn it on or off with the buttonWell do all your cluster lights come on in accessories.
Maybe you blown the fuse under the hood.Na car is not running no crank no fuel pump no pulse it won’t let me communicate to ecu
Un-plug or remove the ABS fuse.Yeh then most go out then trac off light comes on by its self n I can’t turn it on or off with the button
