Plenum and TB spacer
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by Greggles_VS, Sep 1, 2012.
  1. Greggles_VS
    Greggles_VS The Noob
    VS Acclaim V6 Ecotec
    Can anyone direct me to a thread with great explanation of how to make your own tb and plenum spacers, or someone post how to? Dont have the cash for mace spacers :( was thinking i could use some 12mm marine ply and a sealant on the inside to stop air flowing through the ply, using my plenum lid as a template. what sealant would be best, and applied inside or outside the ply. Cheers
  2. HERONVY
    HERONVY New Member
    Steel city
    2003 VY2 SS
    If you really think itll make a difference..
    Use 15/25 mm thick mdf and trace out the shape of the plenum onto the wood aswell as the bolt holes
    After that, cut it out with a jigsaw and sand the edges neat
    Drill out holes for the bolts to go
    Next seal it up with some gasket goo and bolt the lid back on
    Btw youll need longer bolts to compensate for the increased length
    Same process for the t/b
    Sent from my GT-S5570 using Tapatalk 2
  3. Greggles_VS
    What would be the chances of the mdf seperating? And there should be nothing other than air coming into contact with the spacer should there? Is there any speacial sealant to use on the outer and inner edge to prevent leakage?
  4. Drawnnite
    2000 Vs Ute
    it "should" only be air, although if you open up the plenum you may notice a build up from oils and so forth.
    if it were me id probably just try finding a hi temp clear.
    but youll have to do a fair few coats because of how porous timber is. (on a toolbox i made i did about 5 or 6 coats with sanding in between to get a near perfect smooth finish)
    or just try leaving it without any coatings.
    also dont you mean a manifold spacer?
    because wouldnt a throttle spacer do a "similar" thing as a plenum spacer?
    also for Plywood seperating.
    if you mean under the "crushing force" from the bolts, it is rediculously unlikely.
    ive swung liberal weights into a single point before and all it did was slightly dent, nothing major.
    also if you manage to damage it in someway, such as a hammer dent or you drop it etc
    grab your old ladies iron, and a damp rag.
    put rag onto timber with hot iron on top.
    remove and the dents should come out of most timbers.
  5. Greggles_VS
    Well i read that putting a spacer on the tbi so i figured they ment the actual tb but i prob misread it lol. Cheers for the tips and advice
