Plenum Chamber Seals
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by andyman, Feb 13, 2007.
  1. andyman
    andyman The Only 6sp VZ Wagon
    Orange, NSW
    2012 BT50 4x4, 84 Hilux 4x4 & 05 Husky TE450
    For the people who have removed there plenums did you replace all the o ring or did you re-use them, also do the inlet manifold gaskets need replacing and is sealant needed when replacing the chamber,
    i need to take my injectors out to get cleaned so thats why im asking,
  2. ephect
    ephect Donating Member
    VS Acclaim V6
    the o rings are reusable, i've pulled the plenum off several times and i havent had a drama. just make sure u inspect the orings for damage. if they look fine not brittle or marked, they should be sweet
    as far as the manifold gaskets, u mean between the head and manifold? im not too sure, but i would get another gasket just for safety measures. dont know about the sealant, if u need to use it or not.
