Plenum clean
Stretchomatic
35
Ardlethan, NSW
www.facebook.com
86 VL Berlina M5
Hey everyone I cleaned the plenum and TB on my VS V6 today, was relatively easy, didn't go in to deep in the guts of the motor, just what i could see, I also found that cleaning the TB is fairly easy to do through the plenum (didn't have to remove tricky throttle cable lol).
Added a few before and after pics for everyone to see.
quiksilver1
vu ss
mate did you notice much difference in the car after cleaning tb?
Stretchomatic
35
Ardlethan, NSW
www.facebook.com
86 VL Berlina M5
after the whole clean i noticed it runs a bit less revs, used to be just under 2000 at 90km/h now its just over 1500 mark, so yeah just a drop in revs...if i cleaned down the intake pipes that go to the injectors or where ever i'm sure it would be even better. seems maybe a little bit smoother.
quiksilver1
vu ss
sounds worthwhile doing it then.......cheers
Stretchomatic
35
Ardlethan, NSW
www.facebook.com
86 VL Berlina M5
yeah definitely for the hour or so it took, and yeah now that i have asked someone i found out that the intake manifold should be easy to pull off so i can clean in the holes aswell.
quiksilver1
vu ss
just finished cleaning,i removed tb though,quiet easy to remove.car seems to run a little smoother although no major difference.glad i done know i know its done.i would have liked to also taken off manifold but car runs well and i dont want to disturb it will its going nice.
Stretchomatic
35
Ardlethan, NSW
www.facebook.com
86 VL Berlina M5
true...after another inspection i found that there is a fair amount of stuff to remove to get the manifold off...so i might leave it. how did you get the throttle cable off, ive been to soft to attempt to really force the little clip off. and not removing the TB means i dont have to chance busting a gasket aswell.
quiksilver1
vu ss
the acc. cable just pops off.its like a ball socket.i use a screwdriver to gently pop it off.it requires i little force. i think the other cable is cruise control that just slides off with a little force,both pretty easy to remove
