cander24
- Aug 26, 2008
- 992
- 9
- 0
- Location
- NSW South Coast
- VZ GTO. VS LS1.
Ok well that really is strange. Only possibility I can think of is that setup has been retrofitted to a VT onwards at some point??? All the feature there suggest VS, i.e pcv location, gasket types, coolant sensor/sender, metal body injectors, fuel rails. Does the egr valve hole look original?? I suppose it does'nt really matter as you say because all you have to do now is weld up that hole to get it to work for you. The VS utes (including the later series 3 models) never ran the egr valve setup. The VT body was the first to use this. Likewise with the injectors, vt was the first to use the plastic bodied injectors (which have 4 holes in the pintle cap). Are you going to port-match and polish this manifold setup or something a little more customised?
