Plugs for window winder holes in door trim.
Discussion in 'VT - VX Holden Commodore (1997 - 2002)' started by accentstencil, Oct 15, 2006.
  1. accentstencil
    accentstencil Well-Known Member
    Eschol Park, Sydney
    WH II Caprice, 5.7 2017 Captiva.
    I've just finished installing power windows without any problems and I'm looking for some plugs that go into the holes where the window winders were. I can't afford new door trims at the moment so if any one knows where I can get some, I'd appreciate it.
    Thanks.
  2. WAGON MAN
    WAGON MAN Gas Sleeper
    North Coast , NSW
    VX S2 Berlina Wagon with Phreddied bits.
    Try Bunnings you should be able to get some grommets that will fit.:thumbsup:
  3. Charg'd
    Charg'd New Member
    in a ford
    ford
    id say holden would stock them, strangely enough my car has them, which has sorta got me buggered as to why, i thought all hsv, came stock with power windows? sorry for the hi-jack, heres some pics of wat mine looks like with the plugs
  4. accentstencil
    Eschol Park, Sydney
    Thanks for the replies and pictures. Will check it out tomorrow.
  5. djlingard
    djlingard New Member
    Barcaldine
    VZ Executive
    Looks like a neat spot to install some tweeters. Just an idea, what do you think???
  6. accentstencil
    Eschol Park, Sydney
    Not a bad idea except I'm pretty right for tweeters and I don't want to pull everything apart again.
  7. Charg'd
    Charg'd New Member
    in a ford
    ford
    could be, but you would have to remove the whole winder socket, not sure on whats involved with doing that, can anyone shed some light on this, id like to try it
  8. accentstencil
    Eschol Park, Sydney
    Since you have power windows there is no winder socket in the way. You could put small tweeters in the holes providing the magnets aren't too deep. Flush mounted tweeters would be ideal. I have been giving it some thought and it is really a good idea, djlingard.
    Here is a picture of the hole. I covered the hole where the winder spindle was with black tape but you could feed the wires for the tweeters through that hole.
    Charg'd likes this.
  9. Charg'd
    Charg'd New Member
    in a ford
    ford
    under the plugs
    i still have the winder socket there, this has really got me buggered, i thought power windows was a standard feature on all hsv? anyway here is a pic, of what it looks like when you take the plug out
  10. accentstencil
    Eschol Park, Sydney
    Maybe you have aftermarket power windows instaled because that looks nothing like the genuine part I removed or installed.
    The first picture is of the old manual regulator I removed and the second picture is a close up of the spindle which looks nothing like yours.
  11. Charg'd
    Charg'd New Member
    in a ford
    ford
    hmmm, ill pull the door trim off on the weekend & have a look & get some photo's, i dont understand it, like i said, i thought power windows were standard on HSV, oh well, plus all the switches, are all stamped holden??
  12. BigJ
    BigJ Guest
    Try visiting nvu.com.au for replacement door trims. These guys are helpful, fair prices and not gready on freight.:thumbsup:
    Charg'd likes this.
