plugs/ leads
Discussion in 'VT - VX Holden Commodore (1997 - 2002)' started by vxcommie, Jun 1, 2011.
  1. vxcommie
    vxcommie New Member
    perth
    vx executive
    I think i need to change the plugs and leads.
    Any tips for doing this job? and also suggestions on what plugs or leads are a good brand to buy.
    thanks
  2. accentstencil
    accentstencil Well-Known Member
    Eschol Park, Sydney
    WH II Caprice, 5.7 2017 Captiva.
    Standard Holden leads are fine. Bosch, NGK Champion or most well known brand plugs are fine also.
    Pull the leads of the plus by the boots, don't pull the lead. Twisting the boots as you pull will help. Remember what lead went where. Don't over tighten the plugs they don't need a lot of force.
  3. vxcommie
    vxcommie New Member
    perth
    vx executive
    ok thanks, will have to go for a trip to holden soon, i dont think they have been changed in ages.
  4. Dan24
    Dan24 New Member
    2003 VY SS
    just do one by one and u should be sweet. just a matter of replacing what u take out
  5. som
    som New Member
    thorneside qld
    vt executive
    don't forget the black flexible conduit that helps to protect your leads from the heat and consider the genuine leads with the metal boot covers.
  6. Hangman
    Hangman Aspiring Sociopath
    Newcastle, home of Toranafest
    WK Land Yacht
    Should be able to reuse the metal covers, assuming they're already on there. That's what I've always done anyway.
