Pod Filter On A Vs?
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by 1996_Vs_Commodore, Apr 29, 2009.
  1. 1996_Vs_Commodore
    1996_Vs_Commodore New Member
    96 Vs
    How could i put a pod filter on my vs and do without the wire that runs to the original air filter box? I've put a pod filter on my car before and all i got was the engine light non stop until i put the standard set up back in. Can anyone help me so i can have the pod filter on please. Cheers
  2. TrEnNaVY
    TrEnNaVY Donating Member
    VY S V6
    might grab a drink to listen to the old pod filter argument again
  3. delcowizzid
    delcowizzid on holiday
    NZ
    в∞ѕтεכ √&
    haha you need to drill a hole in the plastic intake pipe and mount the airtemp sensor in it thats normally in the airbox.you can mount it in the pod adaptor as well pretty easy.
  4. t-rav
    t-rav New Member
    1995 VS Executive
    just buy a cold air intake off of ebay
    should be able to get it for around $70-$100 then get a K&N panel filter $90-$100
    This will deliver colder air to your engine and will make your engine bay ALOT more tidy =)
    other wise drill away ...
  5. sweefu
    sweefu New Member
    VY Berlina V6 / R31 Skyline
    i agree mate cold air and hi flo panel for sure. i got a genuine s/c cold air intake and k&n panel filter for $150 posted on ebay :)
  6. dbarnes
    dbarnes Member
    Port Macquarie NSW
    VE SS-V M6 UTE
    as said ^ , but if your heart is set on a pod filter, u can get adapters for them at autobarn for about $10 last time i checked, but that was awhile ago..might be a bit more now but go look
  7. ephect
    ephect Donating Member
    VS Acclaim V6
    as posted, u have 3 options
    1.
    2.
    3. pod filter in the airbox, but thats another debate, for another day ;)
    thats it.
  8. itsaholdennotachevymate
    itsaholdennotachevymate New Member
    upper coomera
    95 vs commodore v6 3.8l
    ive heard of a sensor you can buy that plugs into the wires and it reads the air temp a bit lower apparently the stock sensor reads it higher than what the air temp actually is to save on fuel dont know if its true or not but like ive said ive heard of it and seen it done dont know if its and good or not
  9. jas98
    jas98 Active Member
    maryborough QLD
    vs commodore V6 S2 and a BA XR6T
    Thread digg??
    however those sensors are ****...they do more harm then good and i dont see how making your car think its cooler then it is can save fuel as you will be useing more fuel
