Poking hole in rubber grommet for power lead
DavidPartay
somewhat awesome
Central Coast, NSW
2009 Subaru Liberty
Ok, so what's the best way to do it? I've got a VX station wagon, any grommet preferable? Which side is the best to run the power cable? I know you run the RCAs up one side and the power up the other, but what way should I go?
Oh and yeah, the power cable bit :D
Also, what options have I got for filling the bottom half of the double din unit? I heard someone on here (possibly in an old thread) say a Mazda 323 '95 model coin pocket will do it but what other options (aftermarket?) have I got?
Cheers guys!
Tasmaniak
Not a valid input....
S.E. Melbourne
www.ranjinstallations.com.au
Behind the passenger strut tower there is a grommet that I use and also the usual clutch cable grommet.
Generally any Mazda pocket fills the hole and it's also the cheapest.
DavidPartay
somewhat awesome
Central Coast, NSW
2009 Subaru Liberty
Rightio then,
What's the best way to poke a hole through? I was going to try to cut a triangle shaped hole starting from the edge of the hole in the middle but maybe you people have some sort of secret method? The last time I did it to my VN I ended up taking the grommet out and hacking away at it but I don't want to do that to my new car...
sparky
Barossa Valley SA
VX Acclaim Wagon
i just took the clutch grommet out and drilled a hole with a 8mm drill bit. It closed up very nicely around 8ga power cable.
Just chuck a bit of vas or lube on the hole to get the cable through.:thumbsup:
DavidPartay
somewhat awesome
Central Coast, NSW
2009 Subaru Liberty
Sounds like a plan, I tried drilling my last one (didn't work) but using vaso sounds like a good idea.
Cheers guys
StoneX
41
Hastings
VE Calais-V 6.0L
If you have an auto the clutch grommet is solid... You take it out of the car and it is very easy to drill through. Then lube the hole up and stick your cable in ;)
DavidPartay
somewhat awesome
Central Coast, NSW
2009 Subaru Liberty
That's good to know! Should be easier than that rotten soft rubber one in the VN then ;).
Tasmaniak
S.E. Melbourne
put a slice in it with a stanley knife and hey presto bobs your Aunty.
DavidPartay
somewhat awesome
Central Coast, NSW
2009 Subaru Liberty
One day you're gonna say that to someone who has an aunty named Bob :p
Tasmaniak
S.E. Melbourne
bwahahahaha
