Possible to swap VY front seats?
Litoris_Mike
VY V6
Is it possible to swap the Front Passenger/Driver seats in the VY S-series?
The drivers seat is really worn out after 260,000kms and has little spinal support.
:smoking:
edals
Dont think so, the Seat being Electric and the seat belt clip being on the wrong side.
Adds_05
Central Coast, NSW
VT SS 5.7L
i take it you mean the passenger seat over to the drivers side?
if so, im pretty sure you can swap the base of the seats (the cushion part that your bum goes on) over but thats it.
Litoris_Mike
VY V6
Yeah, want to move the passenger seat over to the drivers side. If anything, all i'd need would be the seat back, not the motor or anything.
stock5.7
vy ss oztrack Tuned
You can swap the seat base I did this to the wife's vy,you will also have to swap the rail over on the seat base. Make sure you don't turn on the ignition or you will set of the airbag light.
acarmody
Donati..Whoa Green
VX Berlina
Dont bother swapping over everything. The cushion itself is held in on all 4 sides underneath the seat, long u shaped plastics pieces that hold onto the frame. Simply undo these and the cushion lifts straight up. Left and right are exactly the same.
moriati
vx s
Correct as Carmody explained I did mine like that swapped the cushions and covers together
