Possibly daft question... LCD odometer on dash.
Discussion in 'VT - VX Holden Commodore (1997 - 2002)' started by RK5TAR, Sep 17, 2011.
  1. RK5TAR
    RK5TAR New Member
    VT V6 Manual
    Is the lcd odometer section meant to light up at night when you put your lights on? Mine doesn't. I ask because in my husbands Territory his LCD glows when the lights are put on with the rest of the instrument cluster.
  2. TonyJZX
    TonyJZX Member
    East Coast
    Commodore M6
    yeah it is
    you have a dead light bulb
  3. RK5TAR
    RK5TAR New Member
    VT V6 Manual
    Thanks, I thought it may be the case. One of many dead lightbulbs Ive discovered since Ive had it. I've never had my own car with the lcd display in it before, so wasn't sure.
    I take it I have to take the cluster out to replace it?
  4. accentstencil
    accentstencil Well-Known Member
    Eschol Park, Sydney
    WH II Caprice, 5.7 2017 Captiva.
    Yes you do and I believe the globe is around $16 or something ridiculous like like that.
  5. MikeCuzzy
    MikeCuzzy Jumping puddles
    Australia
    2007 VE Omega 3.6L
    The cluster uses T5 wedge globes, you remove the cluster (and dash) and they unscrew at the back.
    http://forums.justcommodores.com.au...1997-2002/23701-blue-led-dash-conversion.html
    That will give you an idea what you're looking at, they might be expensive from Holden, but most servos should have them for a few dollars for a packet of 2. They are fragile so be careful, best to buy several spares, and when you install them check they all work before putting the whole dash back in. If you get stuck PM, I can walk you through it. When removing them, unscrew the bulb holder and gently but firmly remove the bulb, put the new bulb in the holder and install back in the cluster.
    Also welcome to owning a VT based Commodore - the electrical system is as stable as a thunderstorm.
  6. RK5TAR
    RK5TAR New Member
    VT V6 Manual
    Thanks MC. I will get onto it during the week while the kids are at school.
    LOL@ "stable as a thunderstorm". Sounds like I matched my car perfectly to myself. :rofl2:
    I was changing the seatbelts in it today, and while pulling the pillar trims off inside I thought how much more involved this car seems to be than my old VR to do anything with.
  7. MikeCuzzy
    Australia
    2007 VE Omega 3.6L
  8. Sabbath'
    Sabbath' Redblock Jesus
    80 Series// MK5 GTi//
    9/10 i've had the globe in the mode button blow when taking the dash apart. So fingers crossed yours doesnt go at the same time :)
  9. RK5TAR
    RK5TAR New Member
    VT V6 Manual
    Thanks for the links. Whoever had the car before painted the dash and the little plastic bit inside that surrounds the speedo etc, so its obviously been out before. Thankfully the mode light works still.
