Power Antenna
Discussion in 'Car Audio' started by OZI51X, Aug 31, 2007.
  1. OZI51X
    OZI51X New Member
    sydney
    VX Calais S1 V6
    hey guys, got all the looms wired for my new jvc deck and screen but i am stumped on the power antenna, the deck only has one antenna output and im guessing that is the up power? thinking bout using a relay setup. anyone else had this problem? some light on the subject or an easier fix would be much apreciated.
  2. SweetWagon
    SweetWagon booosted
    Springwood NSW
    VS Berlina Wagon Supercharged
    when i installed a kenwood deck into a VT with power antenna, there was only about 2 wires left over (not sure what colour) but i just connected the antenna remote from headunit to it and it goes up when the radio is on and works like factory. as far as i know there is only a single wire unless you have manual controls then it gets tricky.
    this seems to be a common problem, i will be sure to get the colour of the wire next time i happen to pull it out.
  3. vyaw2003
    vyaw2003 New Member
    vf commodore ute
    mine was only 1 wire on a vx
  4. daron
    daron wizfiz
    adelaide
    VE SSV
    put the blue ant wire from jvc deck to the yellow/red wire in car loom when turn jvc on ant will go up and when ya turn it off it will go down
