power arial not working
BJa
71
2081, COWAN
2003VYCommodore Acclaim wagon
I have a vy commodore acclaim v6 wagon as 2nd owner.when ibought the car the volume control on the factory sterio was not working correctly nor was power arial i bought a brand new factory sterio and installed with power arial not working however the two units were different as the origonal had up down buttons for arial the new one had rew ff buttons but the unit worked fine. now i bought a new power arial but does not work supposed to go up when unit turned on and down when turned off
Question ... is the wiring different for each sterio or does the cars computer have to be matched to a different sterio note all factory items no aftermarket parts note power exists at only one of two wires at plug to arial under guard
thanks for any info
BlackVXGTS
Melbourne, SE
..... power exists at only one of two wires at plug to arial under guard .....
There is your problem:
  • Like
Reactions: BJa
Fu Manchu
WA.
The radio plug is X1. There are three parts/segments to the plug separated and labeled as A, B and C.
A133 is the radio.
Fu Manchu
WA.
So it appears the high end headunit with antenna up and down buttons, is controlled via the BCM. The low end headunit is not. I could have that wrong, because the radio itself is switched on and off via the BCM, but this diagram specifically shows the antenna.
BJa
71
2081, COWAN
SO with the info obtained here i have a fix to my problem . at the plug under the guard the red wire is powered up constantly which causes the arial to go down . and if you then power up the white wire the arial goes up so i put a switch in a line from a power source (cigarette lighter?) to the white wire i then have an up down arial switch and dont have to pull the head unit out and interfer with it
