power ban in a vs wtf!
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by markhayes, Mar 14, 2012.
  1. markhayes
    markhayes Member
    vr commodore v6
    Hi guys got vs 95 spack ,lately in the morn my car has been stiff to take of , the engine stutters when i apply accel. after few second of cruisin it runs mad , as i drive along at about 3,500 4,000 revs something lets loose an the car shoots of easily till the gear changer like a power ban on a motobike its weird but i think there is some damage, its auto too., i recently changed drive shaft cause it **** itself on highway center bearing blew the rubber shook it like a m16 held by an ifant,never stalls always runs its a good car burns hard but this recent problem is shittin me new plugs leads the lot also im in the process of changing power steer pump , my mate tried to burn out in my car an press the brake at the same time after that pump sloly shittin itself could that be screwing with pressure setting causing engine to splatter a little in the morn any help would be great thanks fans
  2. markhayes
    markhayes Member
    vr commodore v6
    hay has any one got any anwsers
  3. monkeys437
    monkeys437 New Member
    Mornington, Melb
    VS Stato l67
    You haven't exactly asked a clear question bud
  4. azkwazere
    azkwazere Ahhh Yes, Ahhh Yes....
    .....SE Burbs
    VP 5-SPD / 24-SPD Racer Hybrid
    All cars have a 'Power Band' so to speak in that there is a specific engine RPM range wich produces the most torque.
    Sounds like either a fuel or spark problem to me (although your post was very difficult to understand).
    aZk.
  5. Jxfwsf
    Jxfwsf Well-Known Member
    Aus
    commodore
    sounds like what happens to a v6 if you flog and thrash it, start with the basics, plugs, leads, filters etc and work up to the bigger components like fuel pump, cas, dfi module, injectors etc
  6. seq4x4
    seq4x4 New Member
    Sunshine Coast, Queensland
    VS
    As above. Plugs, leads, coils and DFI. Then do your fuel filter and/or pump if your up for it. Check your transmission fluid, if to full, too low or black as Ernie dingos bum.
    Also check your error codes. From the sounds of the post the car gets raped alot.
  7. Not_An_Abba_Fan
    Not_An_Abba_Fan Exhaust Guru
    Bunbury, WA
    Strange Rover
    Sounds like a plug issue. Replace them 1st and see what happens.
  8. James39
    James39 Gave up on VL's
    Newcastle NSW
    1995 VS Acclaim & 1992 Holden Barina
    Sounds like you are flogging it. Drive it like normal and see what happens.
  9. yZoH
    S/E Subs, Melb
    (0.o')
    But, What, I, Understand, Uh, What!
    ENGLISH MOTHER####ER! DO YOU SPEAK IT!
