Power button on dash gone?
Discussion in 'VT - VX Holden Commodore (1997 - 2002)' started by mld1, Apr 28, 2008.
  1. mld1
    mld1 F-16 Falcon
    Melton
    VT Executive V6 Wagon
    I have a 98' VT Executive Wagon V6 ecotech auto and the light on the cluster wont light up for the Power Button.I have replaced the power button switch and the tiny globe in the cluster,but it is still not lighting up.All parts where bought from holden.Any one know what it might be?I cant seem to find a fuse for the power button anywhere,so i guess it doesn't even have one.Thanks.:bang:
  2. mld1
    mld1 F-16 Falcon
    Melton
    BUMP.......:cry:
  3. s_ikari2015
    s_ikari2015 Fun IS easier with an 8
    Australia
    '02 Monaro V2 CV8, '83 Subaru Sherpa, '87 Sherpa
    is the power button actually working? Does it hold the gears for longer?
  4. lout
    lout Well-Known Member
    Langwarrin Victoria
    VX Executive S2
    Have you tried the bulb test function?" hold mode and up buttons then turn ignition to on. release buttons then press mode repeatedly until you get to bulb and buzzer and instrument test
  5. mld1
    mld1 F-16 Falcon
    Melton
    Yes it does hold the power for longer.But the light on the cluster just aint workin.
  6. DVS
    DVS D̮̯͓͂͌ͤͬ̌ͣ̈ͧͩ̃͐ͩ͛̔̀͛̑ͯ ͎̞̜
    VT V6
    You have got me stumped, I would suggest you find another cluster and try that.
    Cheers,
    DVS
  7. mld1
    mld1 F-16 Falcon
    Melton
    Can anyone help me with this problem.:cry:
  8. wrx884
    wrx884 WA's ASR Rep
    VT Exec/ VT L67 Spac, 5L VP Calais, 77 TC Gemini
    As said b4 did u try the test warning light fuction using the mode button 2 see if it lights up then or not?
  9. Johnsy
    Johnsy ★★★★★
    C/Town
    VF SS Wagon & VF SV6 Ute
    I Second the motion... do a test first....
  10. Drekko
    Drekko Member
    VX Commodore S series
    Similar problem here but power does not hold gears
    Is there a fuse or relay to replace?
  11. VT&VX
    VT&VX Active Member
    VX Acclaim
    Do a test as mentioned above
