Power Button Problem
ChappyVS95
Perth W.A
95 Holden Commodore VS Ute
Just noticed that my power button isnt being displayed on the screen, and doesnt appear to be working, i press it on and off and nothing shows up, anyone know what would cause this? cheers
Brett_jjj
Tamworth NSW
vs commodore
Does it change how the transmission shifts still?It might just be the globe in the dash is blown.
ChappyVS95
Perth W.A
Doesnt appear to be changing the shifts, and theres a decent different driving with it on or off, ill give it another drive soon and see how it goes..hoping its just a bulb :p
justbad4you
IF YOR NOT A HOLDEN
MELBOURNE S/E BAYSIDE
97 VT BERLINA/ 98 VS SIII MALOO (RED) LX SLR5000
its the bulb mate ....it does change 1st 2nd 3rd and 4th your just tripping? get on 100kmh then hit the button on and off and you will see the revs change on the tacho,,,,,get a full set of globes and do all the globes behind the dash....ps same thing has happend to me...cheeers
ChappyVS95
Perth W.A
haha didnt quite word it rite, alrite i think ill do that this week then. Super Cheap Auto be the place to go?
justbad4you
IF YOR NOT A HOLDEN
not sure.... im pretty sure thay sell em....im going to get mine from gmh at trade price,,,,im doing evry light so ill buy a kit grom GMH....READ THE THREAD ON TAKING OUT THE CLUSTEr B4 YOU give it a shot as you got to be little carfull ass not to brake any clips and so on......good luck when your done,if you know what to do(easily) id do all of them at the same time....that way you at least know thay all should last a while? good luck
Vee-ard
QuickVR95II 2010 Survivor
Bayswater, WA.
Foam Tuned VR 5.0l Ute
doing 100k's and pressing the button will do nothing. the revs shouldnt increase with the TC locked up.
all the power button does is change the shift points to cause it to hold gear until about 900 revs later than it would have done for a given % throttle opened on the TPS.
If he wants to find out if its changed the shift points, do two runs from 0-100 with the accelerator pushed about 50% down equally on both runs. If it holds gear longer on one and not the other, its changed modes.
justbad4you
IF YOR NOT A HOLDEN
mine does it i put it criuse at say 100kmh and push the botton and the rev go up or down very slightly( but thay do go up) and yes your way sound good so may be he will want to try it that way?
