power missing/ not going to wheels
Discussion in 'VN - VP Holden Commodore (1988 - 1993)' started by ashzv6, Sep 14, 2006.
  1. ashzv6
    ashzv6 New Member
    VN v6 s2 Berlina 5spd
    vn series 2 v6 problem
    so i put my manual back into first at 20 and flattened it going to over take,
    and it didnt wanto go past 40km, normally it shoots upto 65/rev limit.
    it was like it didnt wanto rev past 3,000. it wasnt bouncing it was smooth but just not reving up.
    i knew this was bad so i cruzed. hit a higher speed limit and went to flatten it in 2nd, same thing, it was booting then in 2nd at 75km it just stoped reving.
    like i was past the power range or something.
    it had about 10 kw.
    something was stopping it from reving past 3/4000.
    any suggestions.
    i didnt think it was so much the dif/clutch/gearbox.
    more like the ecu going nutz.
    please help
    it doesnt always happen just sometimes.
    and i only noticed it yesterday.
  2. lazza44
    lazza44 New Member
    VN S2 Berlina Wagon
    i think a blocked CAT can do that...I didnt think your meant to change into 1st when going 20kmph. I could be wrong i usually drive an auto.
  3. vt1538
    vt1538 455rwhp LS3
    The Dead Centre
    VY SS S2 11.284@125mph
    Possibly the computer is going into module mode & not allowing the timing to advance. Is there any trouble codes.
  4. VN Commy
    VN Commy New Member
    NZ
    VN 5 spd/VR Calais daily driver
    Ouch! Poor T5...
  5. ashzv6
    ashzv6 New Member
    no trouble codes.
    it only does it sometimes.
    wen i say 20 i was probly doing 10 due to dodgy speedo
    how can i tell if my cat is blocked?
    could it be a computer problem?
    it did it again today in second going flat it wont go past 70/80
  6. xcop5l
    xcop5l 4th year spanner spinner
    ol' geelong vic
    VN ex cop 5L
    reset your computer it could be stuck in limp home mode
  7. immortality
    Sth Auck, NZ
    Does the exhaust have a rattle in it? give the mufflers a love tap(kick) and listen for any rattling noises. sometimes the baffle plates inside the mufflers let go and can partially block the muffler/zorst causing flow issues which normally present as an engine that won't rev very well. mine rattles like a biatch, just never got around to that 2.5" upgrade system
  8. ashzv6
    ashzv6 New Member
    i am compleatly unsure y it does this,
    it was doing it sometimes yesterday.
    I recently got a new exhaust so i doubt its that,
    but my exhaust has got more quiet in the last 2 weeks.
    but i still had a stock rusty and probly blocked cat,
    And massive cracks in the stock headers.
    i will try resetting the comp.
    thanks for all the replys.
