ant797
So had new k frame put in it passed inspecction but pit inspecror pointed out there is a cooling line coming from behind the exhaust manifold to the radiator connecting up with rubber hose and mechanic has put it over the sway bar instead of under wich is causing hose to rub on radiator shroud pretty sure its a power steer ing line because i undid it and it emptied out the steering resevoir...does anyone know the easiest way to get this steel line under the sway bar cant see where it bolts up under manifold or goes to trans if you can even do it that way
