Power Steering Fluid - Need help ASAP
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by Ashahalasin, Apr 26, 2008.
  1. Ashahalasin
    Ashahalasin New Member
    VS Executive
    Hey, everyone.
    I was driving my VS out and for some unholy reason I ran out of PS fluid (despite my car being serviced 3 months ago).
    Anyway, can someone tell me how to put more in, I have the right fluid, i just need to put it in so i can go to work, or else i'll be late.
    Thanks!
  2. whitevrboi
    whitevrboi Just another white vr.
    VR Executive S2
    theres a small black box with a twist lid on it on the front left hand corner of the engine (looking from the front bumper) it says pwoer steering fluid on top. open cap, pour in a little at a time and check the level using the guide on the cap.
  3. woteva
    woteva NEED 4 SPEED
    Adelaide S.A.
    A VS has a white box attached to the fan shroud near the radiator. The previous post has described a VR.
  4. TWOJZ
    TWOJZ Banned
    Adelaide!
    VL shagon ;)
    its the thing with "POWER STEERING FLUID ONLY" printed on it... :s hmm
  5. UNKNOWN
    UNKNOWN DEFECTED
    NW Adelaide
    95 VR SII BT1 5 Speed
    Common a$$ problem!!!
  6. Wagon_Wheel
    Wagon_Wheel Drop A Patch....
    Mt Martha, Vic
    Can i just ask how you knew you didnt have any fluid, if you didnt know where to check?
  7. kopper69
    kopper69 New Member
    VRII Acclaim
    Lol good point!
  8. DannyboyDS
    DannyboyDS Just hand me the pliers.
    VS Berlina
    If it is just groaning?
    90% of groans are the grommet that the steering gear goes through from the cabin to the engine bay. it may just need some WD40 or did you find it all on the floow one morning?
    in short however, the fluid goes in the same place you check the fluid level, take the cap off of the reseviour it is a clear/white box with a black lid located on the drivers side of the vehicle and is mounted to the thermo fan covering.
    Pour some in untill you reach the full cold mark (marks visible on engine side of the reseviour) start the engine and allow to idle, give a few small revs then add as needed to reach full.
    Drive the car aorund the block, stop the car and remove the lid, allow to sit for a few minutes, then add fluid as needed, rinse and repeat, proper bleeding instructions are in the Haynes manual, I suggest you get one.
    I would like to point out this person never said they didnt know where to check, just where to add, allot of people don't know how to top up a trans either, it's not a sin.
