Power Steering Issue
deanis123
33
ACT
VY Calais L67
Hey everyone,
Have a VR calais and in getting it ready to sell, gave it a service (oil+filter, cleaned the engine down, e.t.c) and put in a new power steering pump.
The pump went in fine, no more leaks and mostly a lot easier and smoother turning. But after taking it for a test run when pulling into the driveway or in a parking lot the power steering would pretty much die off (slow and breaking at the same time), unless you hit the gas a bit. Bled it 3-4 times per the manual. Helped somewhat but the problem still persisted, had to drive it 3 hours back from parents to home and now a few weeks later it seems to only be intermittently having the problem, took it for a drive today and it was great until about half way around town running errands and started again.
Could this still be air trapped in the system? The pump is still fair noisy, groaning noise when it starts acting up. How long does it usually take to bleed the system fully?
Or should I start looking at other things? From what I'v read on the forum I should start looking towards;
- belt/tensioner pulley? (Havn't noticed any slippage.. tried turning the wheels stationary with the engine running.?)
- Reseting the BCM? I disconnected the battery for a while, is that different from doing it by the fuse box?
- Variatronic steering issue? Could this affect the steering a slow speed? should i be checking the solenoid + wiring
Does anyone have any other ideas? Or Ideas on steps to diagnose the issue? Sorry for the long post but I have a buyer so pretty desperate to fix the issue asap.
Trying to pull all the threads together, the closest I could find on the forum:
http://forums.justcommodores.com.au...g-failing-intermittently-statesman-wh-v6.html
http://forums.justcommodores.com.au...997-2002/29519-steering-far-too-heavy-vt.html
http://forums.justcommodores.com.au...e-1997-2002/34329-power-steering-problem.html
Big-Al
Banned
Aussie and proud
VY SS 5.7 M6
it can take a while to get all the air out of the system. That's what it sounds like as you have stated that the more you drive it, the better it gets. The fluid can get quite foamy. have a look in your reservoir after a drive with lots of turns and see if it is clean and red or has bubbles in it. Also check your hose clamps are etc are tight, it might be sucking air in somewhere.
frogsta
Sleeper
Mazda 6 MPS 2.3L Turbo AWD
I am having a similar issue, works fine most of the time except when I am going slow or not giving it any gas. I think that points to belt problems or the pump itself is stuffed (check the pulley for play, that was the problem with my old one)
My tensioner arm is slightly bent which needs replacing so that may be my issue
jgtoranalc
Adelaide, SA
Holden Statesman VR HSV 5L, Holden Torana LC
I don't think it would be air in the system, i replaced my powersteering rack which drained all the fluid from the whole system...once fitted new rack i just filled it up, turned wheels lock to lock and it was fine...
K-BAGZ
De Plane! De Plane!
Far North QLD
VR II S-pac V6 Ute / VZ SV6 Sedan / VZ R8
What does the power steering fluid look like when running? Is it bubbly? Just because it doesn't visually leak doesn't mean the pump isn't sucking in air. Know much about aeration and cavitation? These issues destroy fluid pumps.
Any noises coming from the pump under load? (Eg Steering application, lock to lock). I, for one would be double checking the tightness of all fittings and clamps. Even the condition of the power steering reservoir cap o-ring.
What type of fluid did you put in? ATF or labelled power steering fluid?
And as frogsta said, a poorly tensioned belt will give you power steering problems, also reduced water pump and aircon operation.
