Power steering pump oil cooler tubes
Discussion in 'VT - VX Holden Commodore (1997 - 2002)' started by NeddyBear, May 21, 2011.
  1. NeddyBear
    NeddyBear Veteran Mountain Biker
    Emerald, Queensland
    2004 Ford RTV Tray Back & 2004 Subaru Outback 2.5l
    While my VX Commodore was at Pedders on Thursday being lowered they pointed out that the power steering pump cooler tubes had started to corrode and become soft.
    I've now ordered a new tube from Holden for $60.00 and will have it fitted next Friday when I have the auto and engine serviced somewhere else but I'm wondering if this is a comment problem with the Commodores and does the steering pump come with an oil filter.
  2. Darcon666
    Darcon666 Evil is always around you
    At home
    The Wife
    As an alternative... do it yourself.
    For $110(total, PWR Coller +fluid +Hoses & fittings from Pirtek) I bought this:- [​IMG]
    .... I did this to my Clubbie
  3. 87LAG
    87LAG BOOSTED 6 FTW
    THE SWITCH
    VX S S2 AUTO RAPTORCHARGED
    Yes its common thats for sure . . . . The cooler above is ideal though.
  4. morphix
    morphix Member
    Cardiff, NSW
    2004 VZ SV6 5-Speed Auto
    Can you give some info on it? eg. The model?
  5. pablo
    pablo Donating member
    Was a 1997 vt v6 wagon
    I never thought the power steering oil would get that hot that it would need an elaborate cooler!
  6. Darcon666
    At home
    The Wife
    I am involved in the NSW super sprint / circuit racing, very easy to boil the power steering fluid in just 2 laps at some tracks... ;)
    PWO1222 - 280x110x19mm 6AN fitting or PWO1224 - 280x110x19mm 5/16 Barb
  7. pablo
    I think NeddyBear only has a stocky street car, not a race car!....though he might imagine it is at times..LOL
  8. Darcon666
    At home
    The Wife
    The power steering resevior and rack location in our vehicles is crap and so overheats the resevior and makes the material they are made from extrememly brittle over time and that can been seen when you compare a NEW unit to your old one, see below.
    So it's kind of good to up the coolers in our LS1/2/3 powered machinery and as far as I am concerned the cooler your oil runs in a "closed" fluid system like the pover steering, the longer the life of the entire system.
    Good:-
  9. NeddyBear
    Emerald, Queensland
    Yep I have a lowered stock VX Acliam with a maxi flow cat convertor and dual maxi exhausts and the chip is different to standard, don't know what type but I do know its not potato.
    No race car here since I drive my Commodore to last and on the highway rarely exceed 100klms even in the 110klm zones.
    I already have the new tube which does a great job as standard equipment and cars theses days are only engineered to last 10 years but I do have a 1975 Toyota Crown which is still as good as the day it came off the show room floor and has only done 100,000 klms..
    [​IMG] [​IMG] [​IMG] [​IMG] [​IMG]
