Power Steering Pump
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by RoboticCherry-Coke, Oct 1, 2009.
  1. RoboticCherry-Coke
    RoboticCherry-Coke New Member
    Kadina, SA
    VS Calais S1
  2. Sgt Santa Cruz
    Sgt Santa Cruz New Member
    94 VR Statesman
    calais had variable ratio racks maybe?? i dont see why the pumps would be any different
  3. Vee-ard
    Vee-ard QuickVR95II 2010 Survivor
    Bayswater, WA.
    Foam Tuned VR 5.0l Ute
    A lot of people on ebay know sweet **** all.
  4. RoboticCherry-Coke
    Kadina, SA
    VS Calais S1
    lol yeah I know thats why I figured I would come here for advice first :thumbsup:
  5. hako
    hako Donating Member
    Toowoomba SE QLD
    VS11 BT1 V6
    For $12 why worry...and with a feedback of 99.8% on 6903 transactions I'd take their advice. Maybe the upmarket Commodores with the variotronic steering do have a slightly different pump.
  6. VT_Holden83
    VT_Holden83 New Member
    Outer S/E Vic
    VT Commodore wagon series 2
    VS Commodore & the VS Calais have the set up as along as the Calais is a V6.
  7. BlackVXGTS
    BlackVXGTS Well-Known Member
    Melbourne, SE
    If you had read it properly is says "Except for commodore V8 and Calais & Statesman". Perhaps it could have been written differently, but it was really saying that the seal kit is only for V6 models (because V8 models use a different type of pump).
  8. woteva
    woteva NEED 4 SPEED
    Adelaide S.A.
    I got a power steering pump seal kit for my VR V6 from my local repco store for around $15.
  9. admir87
    admir87 Member
    vs calais
    the vs calais has variable speed steering racks, and the pumps have a different valve within them therefore put out a different pressure
  10. Cheap6
    Cheap6 New Member
    VP Exec
    Yeah, the outlets (= valves) on the pumps, V6 and V8, are different between variotronic and standard. You can swap them though - there is a spring in the standard type valve = be ready to catch it.
  11. RoboticCherry-Coke
    Kadina, SA
    VS Calais S1
    So what your saying is that this wont work with my calais? Hmmmm if they are only cheap from retail stores I might just drop into the local sprint and see what I can get there.
  12. BlackVXGTS
    Melbourne, SE
    Not quite correct. The pumps themselves are the same. The speed sensitive rotary control valve that varies the pressure is attached to the steering rack.
  13. Cheap6
    Cheap6 New Member
    VP Exec
    While the pumps are the same it is the outlets that are different. The standard type valve contains a spool, spring loaded, that varies position and hence restriction, with flow rate. The pump outlet for Variotronic has a fixed orifice. Swapping them is so easy it's trivial.
  14. pwrslydn
    pwrslydn New Member
    Bris
    VQ Caprice/ Mazda Astina
    I have just discovered the my VQ caprice is runnin the varoitronic rack with the standard type power steer pump, tried to figure out why the steering had always been a bit weird. Point being is I have a stuffed Variotronic solenoid (wiring loom for the solenoid has somehow come to rest on the exhaust and stuff the whole thing) so if you take the guts out of the valve on the soleniod and bolt it back on and run my existing standard type pump would that be ok????
  15. 355VQSTATO
    355VQSTATO New Member
    VQ S2 Statesman V8
    yea mate sould be all good my ser2 vq stato had the same rack the person before my had it disconneted and after i put the new paccys on her i had to put a standed vp power steer rack in as the old vq rack with the variotronic solenoid would not clear the new paccys and i also still run the same pump if thats any help to you dion
  16. pwrslydn
    pwrslydn New Member
    Bris
    Thanks for the info....Im am prolly gonna do the non variotronic rack conversion anyways just need to get the right intermediate shaft for the conversion and go from there.
