Power Steering Reservoir 92202130
VS_Pete
Donating Member
Just a heads up need a new reservoir or hard to read retail $81.98
Will fit many holdens. Check with Holden.
losh1971
North Tas
VE Series I SS Ute
Is that a VS one? I can not see if fitting a VR V6.
vs-lover
VS S2 Calais, VS S2 Exec Wagon, VS S2 Acclaim
That's one expensive piece of plastic isn't it ?
losh1971
North Tas
VE Series I SS Ute
Looks like a part that would become brittle over time, hence the need to buy new. Where as a VR one you could buy SH as they are fairly robust.
VS_Pete
Donating Member
VS_Pete
Donating Member
Check with Holden.
I saw then at work and thought I`m put it up because I didn`t think they would be available anymore.
losh1971
North Tas
VE Series I SS Ute
I thought you must have bought one for your bus. I'd say 99% it won't fit a VR as the inlet sucks through a hole in the bottom on a VR and not a flared fitting like the above has.
losh1971
North Tas
VE Series I SS Ute
