power steering
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by brend94vr, Jun 12, 2011.
  1. brend94vr
    brend94vr Member
    sydney
    vr commodore executitve, manual vn executive
    hey, every time i turn the wheel in my vr theres a rough sound like parts moving with no lubrication, i have checked the fluid level and theres fluid in there. got told by a bob jayne t-mart guy that the steering rack is leaking, so as soon as i got told that i went to the mechanics and they said its fine, could it just be the power steering pump????:hmmm::hmmm:
  2. Bourbonated
    Bourbonated New Member
    Newcastle
    VE SV6
    Check that out before moving any further.
  3. brend94vr
    brend94vr Member
    sydney
    ok dumb it down for me haha, whats the bulkhead?
  4. hako
    hako Donating Member
    Toowoomba SE QLD
    VS11 BT1 V6
    It will be the grommet located down the bottom of the steering column where it goes through the firewall - the column turns in this plastic grommet and make a whiny/moany sort of noise whenever it's turned. Fix is to spray with WD40 or similar - best access is from under the car looking up. This problem is very common and lots of people have been misled by unscrupulous mechanics who are out to make a fast buck.
  5. brend94vr
    brend94vr Member
    sydney
    so i gotta jack up the car yea?
  6. Bourbonated
    Newcastle
    VE SV6
    Well.. Yeah.. Unless you're skinny enough to get under there without jacking it. I usually just chuck it up on ramps briefly.
  7. brend94vr
    brend94vr Member
    sydney
    i have a trolley jack and stands so that should do, aite awesome thanks guys its a bloody annoying noise
  8. BlackVXGTS
    BlackVXGTS Well-Known Member
    Melbourne, SE
    I just put some grease on the end of a thin stick and use it to lubricate the grommet. Easy and you don't need to jack up the car.
