Power window problem
Shape1223
19
South Australia
Vu commodore
Hi I have a 2002 vu commodore, I have just recently had it manuel swapped. Ever since I have had it swapped my driver side window won't go down, I can hear the relay click when i lift the switch up but not when i push it down. I have had the power window switch swapped out with a new one , just wanting suggestion on what to do next?
accentstencil
69
Eschol Park, Sydney
WH II Caprice, 5.7 2018 Equinox LTZ V
Did you install a Driver's Window Relay?
accentstencil
69
Eschol Park, Sydney
Try connecting 12 volts directly to the terminals of the regulator motor, reverse polarity to change direction, up or down.
If that checks out ok check the wiring for the window in the door loom.
Trevor loves holden.
vs commodore
Break in the wire between the door and kickboard, remove door card and jump a wire from behind the kickboard to actuator if it works you have a broken wire, also you can just hook up a battery straight to the actuator and see if its not dead. Why its out replace the plastic slide clips
