Power window
Discussion in 'VT - VX Holden Commodore (1997 - 2002)' started by Drumnath, May 12, 2012.
  1. Drumnath
    Drumnath New Member
    South Australia
    Ve sv6 ute
    Im installing power windows currently into my vt accliam I had all the wiring from the main switch up to the doors so I put electric window door loom in and I put the relays in and everything and I tested out the window regulated out before I fitted it but I only get power on way thro the regulated any idea what it could be I've tried putting both the front window regulators on it ?
  2. accentstencil
    accentstencil Well-Known Member
    Eschol Park, Sydney
    WH II Caprice, 5.7 2017 Captiva.
    Have you connected the rear window switches? When I installed powe windows it wouldn't work properly without the rear switches connected.
  3. Drumnath
    Drumnath New Member
    South Australia
    Ve sv6 ute
    I've been reading that a few ppl have had problems with the drivers door bout bypassing the bcm cause it will only go up but not down and the answer to ur question is no I havent but I will tomorrow and I only get the regulator to go one way and the other way has no power so ? But I'll do the other three tomorrow and also could I connect up a tech 2 to tell the car that it now has electric windows ?
