Alex6999
- Apr 23, 2017
- 5
- 0
- 1
- Age
- 29
- Location
- geelong
- vt series 2
in the process of getting my vt on the road.
one of the problems with it is the power windows don't all work. left side windows work (front/back) but the right side windows don't work.
i've pulled the drivers door power window motor out and wired it to the battery and it works, both directions.
when i plug it into the loom and use the center switch it only moves up.
pulled the switch apart cleaned it, also tried to bridge the connections on the switch. that didn't work aswell.
i've changed the relays over. checked fuses.
unless i have the wrong relays in there. (the pins on the relays match the socket on fuse board )
anyone able to share some knowledge, on what could the problem be?
thanks.
thanks.
