Powerglide Question Ls1
VL_Ls1_turbo
VL Calais 5.7 turbo
Hi ,
Does anyone know what the box patten be for a powerglide to a Ls1?
would it be a Holden V8 patten?
or
A Chevy v8 patten?
I need to know off someone who done the box swap before.
cheers
delcowizzid
on holiday
NZ
в∞ѕтεכ √&
power glide should be chev pattern
Calaber
Nil Bastardo Carborundum
Lower Hunter Region NSW
CG Captiva 5 Series 2
Powerglides had separate bell housings, so they could have both Holden or Chev bolt patterns depending on what they were originally fitted to.
VT-565
QLD
VT
6 cylinder cases are 2 piece, V8 cases 1 piece I'm pretty sure.
GMMAD
Nowra
3.8L GT35 4runner/VK calais
there a chev pattern which is slightly different to LS1 pattern
but can be modded to fit
BradSV8
Nitrous Junkie
41
VY SV8
From what I have heard you need a bell housing with a turbo pattern. I think any gm trans with a turbo pattern will bolt up to an LS1. Your best bet would be to ring a trans place and ask them they should be able to tell you straight away.
