pre-apprentice needing help
michealh877
perth
stock standard vs
I'm stuck on an assessment . When the park lights are on and I turn the indicators the park lights flash in opposite time to the indicator . Any help is appreciated
wraith
Hand over the dog bikkies
Demonicaland
VX V6 Berlina. 2003 VW Passat
So wait you want us to do your assessment for you.
wraith
Demonicaland
Jxfwsf
Aus
commodore
check the globes and sockets for corrosion, bad earth as stated above and the globes are earthing back through one of the positive filaments instead of the correct negative (hence going out completely when both sides are @ +12 volts), most likely be a bad negative connection from the loom to the vehicles chassis/body if all the globes are doing this instead of 1 or 2/only 1 side.
Tasmaniak
Not a valid input....
41
S.E. Melbourne
www.ranjinstallations.com.au
^^^ Snappity Yap!
In the words of the great Meatloaf.... You took the words right outta my mouth
Don't worry about the next line though :p
Except when driving anything older than VN, at which point... Situation normal. lol
Sabbath'
Redblock Jesus
80 Series// VFII Black Edition
Need to cycle the flux capacitor and rotate the muffler bearings.
Tasmaniak
41
S.E. Melbourne
Other possibility is that someone filled the indicator globe with Xenon gas instead of Halogen causing an overflow effect into the parkers.
Just a thought.
axemurderer101
Albany
forums.justcommodores.com.au
VY SS
Carlisle tafe? I did a pre app there too lol, finished my apprenticeship a year ago.
