Pre drilled Wheels on a VF
Mitchell Gray
Cessnock
VF Series 2 SV6
Hi,
I have a 2015 VF Series 2 SV6.
Im looking at a set of VF SSV Redline wheels on facebook and the bloke has a set.
They are 2 x 275/35/19
17 or 18 inch- staggered
4 have been pre-drilled was on VY Tonner.
With the pre drilling done, will they still fit ok on the VF?
Thanks
_R_J_K_
Zenki S14
That just means the centre bore has been enlarged so they will fit on a pre-VE Commo. You just need to get some hub lip spacer rings to fill the centre bore back in. Ebay ones will be fine.
panhead
NSW Central Coast
Cars
Hi,
Thanks
275/35/19 is the tyre size.
275 wide – 35% sidewall height – to fit a 19 inch diameter rim
17 or 18 inch staggered – I didn’t know Redline rims came in those sizes.
Are they genuine Redline rims – if not then you should also check the offsets or they could look odd on a VF.
You'll definitely need the hub centric rings as pointed out byb rings _R_J_K_
Also the bolt holes on the VF are bigger than the VY so check to see if they have been sleeved.
Mitchell Gray
Cessnock
VF Series 2 SV6
Thanks guys,
Im gonna pass on these ones. Treads a bit **** apparently too
