HiIn full swing! L76/4L65E next to soon to be installed LSA/6L90E. While the 6L90E is overall about 50mm taller, a lot of it is at the bottom. The extension housing on the 4L65E is about 5.5" longer than the 6 Speed so the tailshaft will need to be lengthened and also the front tripod swapped to a VE/VF V8.
Got a few bits and pieces to swap over such as the sump, engine mount brackets, valley cover and rocker covers. Some of the front driven accessories will need to be changed over as well since the AC compressor and PS pump pulleys will not align to the VE/VF configuration. The crank pulley from the L76 will need a key way cut to fit onto the LSA crank too.
Are you able to give estimates on completing the 6 speed auto upgrade?
