Price on some engine work for a E1 GTS?
Discussion in 'VE Holden Commodore (2006 - 2013)' started by pjdm1980, Dec 6, 2011.
  1. pjdm1980
    pjdm1980 Shut up Jr I'm thinkin!
    Geelong, Victoria
    E1 GTS BUILD NO# 007, GQ Patrol.
    I've got a couple of quotes but they vary a fare bit and I'm not quite sure if some are to cheap/expensive so here goes, the quotes all involved the following work
    - Cam
    - Lifters
    - Dual row timing chain
    - Shaved heads
    - Double row timing chain
    - Tune
    and the quotes ranged from $4600 to $5700 does that sound about right?
    I'm open to all opinions/feedback, and I plan on booking it in next week or so.
    Not sure if I've put this the right section but if I haven't then I'm sure someone will move it.
  2. OFF T4P
    OFF T4P Donating Member
    townsville
    383 HSV GTO coupe & vk ls1 turbo
    that seems about right it will vary abit depending on what brand parts they are using
  3. Nuddy989
    Nuddy989 New Member
    Mackay
    VE SSV
    cam package that includes double row chain, springs, retainers and lifters is about 1500 in parts then the tune about 1k. fitting the cam pack about 1k then the headwork i'm not 100% sure lol so it all seems about right to me
  4. bigjim92
    bigjim92 Active Member
    2016 VF SSVR
    Those prices sound fair.
    With the work you want to do, I would be more than happy to pay a few hundred dollars more knowing I'm taking the car to a place with a good reputation.
  5. pjdm1980
    Geelong, Victoria
    I'm getting a 3000RPM stall as well so now just to find the right spec cam but it won't be happening till after Xmas as the shop is shutting down for the holidays and is booked out till then.
  6. bladerunner
    bladerunner "needs a bit'a nitrous"
    brisbane nth
    VE SS UTE & a 71' deltek rockhopper
    might pay to plug a nice big cooler into the box or at least run a full synth fluid (runs much cooler but expensive to fill) if you plan on running a stally. thought about a set of diff gears as well? maybe a 3.7 or even a 3.9 ratio would be sweet
  7. pjdm1980
    Geelong, Victoria
    I'll get it changed while they're at it and check the size of the cooler when I'm down there next, it has 3.7's from the factory.
  8. SilverVH
    SilverVH Banned
    You mean 3.27's :hmmm:
  9. pjdm1980
    Geelong, Victoria
  10. SilverVH
    SilverVH Banned
    You are correct, it does say that. Unfortunately they are wrong lol.
    *edit*
    I will elaborate a touch.
    HSV use both the 3.27 and 3.7 for auto and manual transmissions respectfully. The part number's are common GM part number's 92223668 (3.27) and 92223667 (3.70).
    In the VE series, differential breakdown for V8's are:-
    Commodore:
    2.92 for auto
    3.45 for manual
    HSV:
    3.27 for auto
    3.70 for manual
  11. pjdm1980
    Geelong, Victoria
    Just look in the owners manual and turns out your spot on!
  12. ducker85
    ducker85 Active Member
    Narnia
    09 VE clubbie R8
    heard a rumor some HSV's are 3:45 auto and 3:9 manual.
    rumor not fact I dont know what model or anytihng
