Wilf
- Feb 13, 2022
- 3
- 0
- 1
- Location
- Melbourne
- 09 VE Commodore International - LPG
I'm after some advice on an alternator light that's just popped up on my 09 VE International - LPG/Dual Fuel.
BACKGROUND:
Recently purchased a 09 VE, and don't know much about the service history.
Had an issue with the alternator about 3-4 weeks ago. On a quick drive the battery saver mode came on, and engineering mode confirmed car was sitting at ~10v and declining. Took it into a shop to get the alternator replaced. Battery died in the driveway of the shop, but a quick jump it had enough juice to drive onto the hoist.
Alternator replaced, apparently brand new OEM.
ISSUE:
Earlier in the week, started the car and got the "Alternator" warning message in the instrument MFD, and the battery light is illuminated.
Checked engineering mode and battery charge was 50%+ and battery voltage was 14.5v+.
Have restarted it about 4-5 times since then and always get the alternator message, and battery light it on all the time.
TROUBLESHOOTING:
So far I've checked:
QUESTION:
Has anyone had the same problem, or any idea what the issue is?
It seems like the battery is charging, and voltage from the alternator is present and the regulator is working fine (and I'd expect the alternator to be fine as it's all just been replaced).
I did have concerns about the battery, as it did die during the battery saver mode incident (and I don't know how old it is) - but it's showing 12v without issue.
I've read a few other threads that mention regulator or dying alternator, but I don't think they are the cause here.
BACKGROUND:
ISSUE:
TROUBLESHOOTING:
- Voltage at battery - engine off: ~12.1v consistently
- Voltage from engineering mode: ~12v down to as low as 11.9v
- Voltage at battery - engine on: ~14.5v - but does fluctuate slightly
- Voltage from engineering mode: ~14.5v - again fluctuates slightly
QUESTION:
