problem with battery going flat
richie351
statesman driver n luv it
w.a
VRcommodore
hey guys i have a problem with me vn 5l .. the battery light stays on all the time and sometimes it dies out .. runs fine all day cranks over perfectly normal.. bring it home go to start it in the morning and battery dead flat... i dont know if i using power somewhere.. if i jump start it and go to shop . turn it off and start it again its fine.... plz help :bang:
thanks
VN Lukey
BT1, the way to go
Holden VN S1
Hey mate...
i had a simmilar problem...
idd deffenently say it would be your alternator..
but before you change that because its a bit expensive... rip out the Regulator behind the alternator and you should see 2 tooth like bushes and you would be able to tell if they are worn bacause they would be very short... the problem would be that the bushes are not making contact to charge...
a regulator will set you back about $50 from Repco.. i think.. i replaced mine not to long ago and my alterator is fine..
good luck mate.. hope i was some help
LUMPY 8
buddaboy1990
30
SAs biggest retirement village (victor harbor)
Vu r8 maloo, mq patrol beach bus
b4 u go rippin out the alternator do a few checks first.
Check 2 c if its charging.
Check the charge wire.
Check battery and make sure the acid levels r good.
Make sure all lights r off (check boot light)
Then of ur 100% sure its the alternator, take it out and check the bushes on the back
camstatic
I'm back babeh.
Regional SA
VZ SS
+1 to checking the boot light isn't staying on :)
