QUOTE=holdenboy;1181413]I think the main problem with "tapping" into exsisting constant power sources is the fact the stereo draws its current from this wire (10A), and this may overload the fuse, so the user replaces it with a higher rating one and ends up frying the stock wire. (Have witnessed this a few times now).
It does "work", but its not the proper way to obtain constant 12v, thats all.[/QUOTE]
Yes you are right, but the constant power wire really only supplies the memory with power (clock, Radio Presets etc....)I have never seen a constant power wire draw 10A, however I have seen people pick up power from other sources and overload circuits and I think from memory the fuse on the clock circuit is rated at 10A. (It has been a while though....).
I have also witnessed people "tapping" into the brake switch wire and caused all sorts of problems..
cheers
Simon
