V
VKBoy
Guest
Hi all,
ive recently just bought a VK station wagon, but ever since then ive been having the strangest problem!
It drives fine for about 20-25 mins, then all of a sudden it just loses power. The vacuum goes down, and the car just slows down till the engine stops. It sounds like its losing fuel. If i let it sit for about 5 mins, and try to start it, it coughs and splutters like its starting to get fuel, then it starts and goes fine for another 5 minutes then it all happens again.
Its just not driveable! Ive changed the fuel filter, spark plugs, leads but so far no luck. Tomorrow im going to change the fuel pump to see if this fixes it, but im not sure if it will as the carby gets fuel fine.
The vacuum gauge in the dash comes from the carby doesnt it? So wouldnt that mean that if its losing vacuum in the carby, that the carby is the problem? Its a varajet.
Also the engine temp does not rise, but when starting the car and for the first few minutes, the oil pressure gauge stays at about half, but after about 10 minutes it goes down into the red, this is confusing because i know the car has plenty of oil!
Please can someone offer any advice? I desperately need this car on the road!!
Thanks,
VKBoy.
Thanks,
VKBoy.
