Problem......
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by beetle81, Nov 14, 2006.
  1. beetle81
    beetle81 Guest
    does anyone know what would be wrong when your engine just drops off when you stomp it, it happens bad enough when you stomp it around a corner the engine cuts out and you gotta stop the car and start it again.:ranting:
    any help would be awesome.:thumbsup:
  2. pow3rslave
    pow3rslave DoNothing Member
    eastern subs, vic
    VP 5.0L
    could be that you're flooding it, how's your throttle set?
  3. beetle81
    beetle81 Guest
    not really sure, how do you check?
  4. yZoH
    S/E Subs, Melb
    (0.o')
    Flooding EFI....
    hahaha Now that's funny...
    MaT
  5. beetle81
    beetle81 Guest
    i think not
  6. pow3rslave
    eastern subs, vic
    VP 5.0L
    sorry bro, made a bad joke.
  7. calais_cruzin
    calais_cruzin Calais_Rattling....
    Gold Coast
    92 VP Calais 3.8
    hows ya fuel pump sound could be loosing pressure wen u stomp it....
    They get really loud wen there stuffin up
  8. protossw
    protossw New Member
    VR 3.8 EXECUTIVE
    Exactly the same problem with me.
    Try to check the fault code first.
    If you find CODE 47 or similar related to crank angle sensor, I am 90% percent sure you need to change it.
    It will cost you around 50 plus labour.
  9. fitzy2005
    fitzy2005 New Member
    Wide Bay, Queensland
    VY S2 Berlina
    also your injectors maybe dirty
  10. beetle81
    beetle81 Guest
    i will try checking the fault codes first, and will see what happens
  11. beetle81
    beetle81 Guest
    fuel pump sounds.... well i cant hear it, so it must be ok cause i thought that too.
  12. vt1538
    vt1538 455rwhp LS3
    The Dead Centre
    VY SS S2 11.284@125mph
    Could be a faulty fuel pressure regulator.
  13. beetle81
    beetle81 Guest
    how do you test the fuel pressure regulator?
  14. immortality
    Sth Auck, NZ
    with a pressure gauge
