This maybe the issue as they use 5v on commodore, its in the installation guide,
Problem: “ECU tach output is only 5volts”
- If the tach output from your vehicles ECU is only 5volts, a 10K 1/4 watt resistor is needed to increase the signal voltage to 12volts. (Nissan, Subaru, Etc..)
Installing a resistor: Connect one side of the resistor to the green signal wire of the tacho and connect the other side of the resistor to the red 12volt ignition wire of the tacho. Do not cut any wires, just splice into.
WARNING: Do not connect the resistor to any other wire or you WILL damage the tacho and your ECU!
