Problems wiring up PRND321 on cluster
Discussion in 'VT - VX Holden Commodore (1997 - 2002)' started by Dayvo, May 2, 2013.
  1. Dayvo
    Dayvo Because i can
    South East,Victoria
    VE SV6 Series 2
    I installed a level 3 cluster which was supplied by another a JC member ( thanks 88Green VN top bloke ) and programmed to suit my VX ( thanks Phreddy , good guy ) .The problem is that i’m having trouble connecting the loom from the auto trans to the BCM . This is the sockets where they plug into but the problem i an having is that E7 already has a black / red wire connected to it . Has anyone else come across this problem because on one an any forum and thread i have read about it has had this problem . The “D” does light up on some occasions for a split second when i turn off the ignition .
    PCM: cavity E6 = Auto Transmission PRND321 socket: cavity A
    (Blue wire / White trace)
    PCM: cavity E7 = Auto Transmission PRND321 socket: cavity D
    (Yellow wire)
    PCM: cavity E8 = Auto Transmission PRND321 socket: cavity B
    (Grey wire)
    PCM: cavity F15 = Auto Transmission PRND321 socket: cavity C
    (White wire)
    Thanks Dave
  2. uniacidz
    uniacidz Harden the Frak Up
    Sideneee
    VE Berlina
  3. Dayvo
    Dayvo Because i can
    South East,Victoria
    VE SV6 Series 2
    Thanks mate , I had a look at this earlier . I have the correct loom but the problem is I can only connect 3 of the 4 wires because the 4 one already had another wire connected in the plug on the BCM. The funny thing is that although the loom is disconnected the "D" on the cluster will flash momentarily .
    Thanks .
  4. 88GreenVN
    88GreenVN Next Exit Left
    Surprise, Arizona
    Dodge Ram Van 1500 5.2 V8
    No one has the answer????
  5. oska
    oska Active Member
    vx custom 600RR
    the black wire with a red trace is GND just splice it together
  6. 88GreenVN
    Surprise, Arizona
    So splice the yellow (E7) with the black red wire and all should work? :)
  7. Ian Johnston
    Ian Johnston Active Member
    Mount Gambier, SA
    2015 Subaru Forester, XR6 turbo ute.
    Wont you have to change the BCM to suit the 3 window?
  8. oska
    oska Active Member
    vx custom 600RR
    i misread the problem
    use this wiring diagram
  9. lout
    lout Well-Known Member
    Langwarrin Victoria
    VX Executive S2
    are you trying to connect to the ECU (left kick panel)
    or the BCM above accelerator pedal
  10. uniacidz
    Sideneee
    VE Berlina
    My car, VX SS had cluster upgraded, worked fine. Sorry to. inform that
    Didn't have to upgrade anything else
    Sent from my HTC Aria using Tapatalk II.IV.X
