Problems with my vr acclaim
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by ShawtyNate, Jun 6, 2011.
  1. ShawtyNate
    ShawtyNate In the feels.
    I have some problems with my vr
    Ill be driving around for a while, stop and turn off my car. i go to start it and it just ticks? i rattle the battery around and it starts? is it a loose wire or is it my battery or something else?
    Also it sometimes dont start so i have to put it in gear and try start then it starts, i got told its the ignition so i brought a new one off my mate because hes a machanic and he said that you can use that key from the new barrel for all doors, all you have to do is pop the pins out?? what does he mean by that.
  2. hako
    hako Donating Member
    Toowoomba SE QLD
    VS11 BT1 V6
    Check the battery terminals - they should be clean and tight....not loose or covered with corrosion. Re the key barrel, what he means is you can disassemble the new barrel and re-arrange the pins to suit your old key.....re the put into gear to start, that possible is a mis-adjusted inhibiter switch on the auto transmission....your mechanic mate should know about that.
  3. ShawtyNate
    its a manual though, and ill check the battery tomorrow.
