probs with a 5 litre starting
VN-SV-89-LE
Melb
VN BT1 5 Litre 5 Speed
hey all,
iv got a VN 5 Litre, and one night from dropping the missers off, the beast desided to stop and wouldnt start again. :bang:
I've tryed every thing i could think of, it turns ova and goes to run for about 1 to 2 seconds then shuts off, the fule pump is working coz i can hear it, iv changed the internal fule pump, it wasnt that so my old man thought it could be the coil, still it wont start and run.
i was told from a guy at work that it could be the crank angle sensor or something, i dunno iv givin up, i just wont it to be running again lol, i miss it, but if any one can think of y it wont run, plz let me know or ngive me some idea to work with coz im just lost and to me the next step is to take it to a mechanic wich i dont really wont to. i dont trust em!:ranting:
anyway guys if u can think of something that it could be plz let me know thanx.;)
vpbt1ss
VR SS manual
another common thing togo on them is the ignition module thats sits behind the airbox in front of the stut tower look on ebay as there r normally cheap new ones on there
VN-SV-89-LE
Melb
is that the little black box in the engine bay on the firewall or r u talkin about some other black box, and the box ur talkin about is it hard to get to and replace?
xcop5l
4th year spanner spinner
ol' geelong vic
VN ex cop 5L
its an alloy looking thing with a chrome circle in it on the pasenger strut tower
not hard to get and to replace you unplug the old one and plug in the new one
VN-SV-89-LE
Melb
Oh sweet thanx for that guys ill try it tomorrow, when i get home from work. i hope it will work coz i wont to take her to the car show tomorrow night
pandaman
Aussie Muscle Fan
VN Berlina 5.0 A4
It's not real effective just replacing stuff at random that *might* be the problem. There are three main reasons why an engine won't start, lack of spark, fuel or compression. It's damned easy to check if you have spark, just pull plugs one or two at a time, and get someone to hold them near the side of the engine bay while you turn it over, if they all spark then thats not the problem. If you've got no spark then you can turn your attention to why. You've said that it starts momentarily but wont run, so spark probably isn't the problem, but it's so easy to check that there's no reason not to. Anyway, if you've got spark then the ignition module is probably not the problem.
Once you've eliminated spark as a problem, then fuel is the next thing to check. If the fuel pump is running and pressurising the line then fuel filter, regulator and injectors would be the next suspects. Just try to approach it logically yeah?
xcop5l
ol' geelong vic
VN ex cop 5L
i had a car in at work with the same symptoms. checked spark while cranking checked the fuel presure at the fuel rail checked the injectors were pulsing did a compresson test.
had the module tested and it was faulty.
fabz
I Can Do Science Me
40
In My Car!!
Blown V6 VT commodore 5 speed
BCM is my 2 cents worth.... should make a bet about the prob until he finds it. Winner takes all.
VN-SV-89-LE
Melb
iv givin up so im gunna take it to the mechanic's and they can deal with it coz im just fed up with it and i just want my power back in my hands :D
pandaman
Aussie Muscle Fan
VN Berlina 5.0 A4
Yeah? dang, thats one tricky little bastard of a component then. In my experience when the ignition module dies the car wont even kick, but I suppose that's one of the hazards of the electronic age, things often aren't as simple as they seem.
