Project Commodore
NPreston
Victoria Point
VC
For anyone interested here is a photo of my project 18 months in the making part time of course. My aim was to take the car as far as I could and still be able to get it registered, makes it much easier for tuning etc and it is only a 10 minute drive to the local hill climb. Has a 3.8 Buick and T5. I went with the V6 over a V8 becuase the car has been built primarily for hill climbs and street sprints running in the 3000-4000cc class. In theory the V6 should be better balanced without the extra weight of the V8 hanging over the front. It is fully complied and was registered last Monday. Just over 100kgs has been stripped from the interior and with a near full tank of fuel it weighed in at 1150kgs. Wheels are 17"x8" running "R" spec semi slicks. Not the greatest thing to drive on the road but hopefully should be good on the track.
vk.jonno
south east
Vk commodore, hq one tonner, hj ute,
looks good bro
TY318
VH SL 202
not bad i wouldnt mind getting another car and doing this well mostly the uphill climbs i dont think i would do it with my car incase i come off the edge hahaha
Lamo
VK SL + LH Torana + VZ Crewman
Nice. Anymore info/pics on the conversion?
50LTRv8
VT V8 Calais
Looks good man, do you have any pics/comments of the build process?
NPreston
Victoria Point
VC
I've more photos here I'll see how I go posting them. The engine has high compression pistons with the block milled to get correct height, balance shaft removed and fully balanced, double row timing chain, lightened flywheel, billet Tighe camshaft, 70mm throttle body, Mitsubishi Magna injectors, upgraded Pierburg EFI pump, headers, mandrel bent 2 1/2" exhaust with one muffler, $2000 spent on cylinder heads, all ports matched including the throttle body, Haltech computer and running 10.5:1 compression. Clutch is a solid centre job clamping pressure is 2400 pounds if I remember correctly, I know it's heavy. Rear axle is VL turbo 4 pinion lsd 3.45:1 with billet axles. Suspension is Just Commodore with King springs Koni sport adjustable shocks, camber adjustable strut tops and poly bushed all round. Vt brakes, 25mm master cylinder. Battery in the passenger footwell rear lhs.. Interior is just painted metal. The car is registered as a two seater only. Build cost around $17,000 so far.
Lamo
Hold on to your hats boys - here comes 37 pics of this very cool Commodore!
Lamo
Initial preparation, worst jobs of the whole project were cleaning the bitumen off the floor and transmission tunnel and painting the interior. My nostrils were stuck together despite wearing paper masks, also my eyelashes stuck together requiring delicate application of turps to seperate them. There was a total of 16kgs of bitumen in the car. Before and after shots of the engine bay.
Steering is VL power steering and the cross member is from a VS, cheaper to run power steer than buy an idler pulley to delete the power steering pump. Be an advantage with 225 "R" spec tyres.
Lamo
Engine and additional wiring harness required. Radiator is a VN V8 Fenix aluminium unit modified to fit the VC. Bottom locationg pins had to be moved and I had to block off the bottom outlet and move it up 75mm. VT calipers and rotors.
Standard air inlet as required by Qld Tpt along with a standard unmodified engine and computer, oh yeah it's standard just runs a little rough.
Lamo
Radiator in situ.
Optima fully sealed Absorbed Glass Matt battery, no hydrogen gas when charging. Battery wiring with isolator.
One of two adaptors for my cold air intake. Original inlet is blocked off. Intake is under the front bumper which on a Lexus is the highest air pressure point apart from immediately in front of the windscreen, stumbled upon that little gem by accident, I guess it would apply to the Commodore as well as they are both 3 box cars. Bottom photo is the air intake sensor that I moved from the rear of the inlet manifold and placed in the air intake itself. On the dyno before I moved the sensor the air intake temp was higher than the water temp.
