I like where this is going
The only things that ushered me away from ever doing an LS1 conversion is the cost of replacement parts:
1) $150 worth of spark plugs
2) $600 worth of coil packs
3) $120 worth of oil per change
4) OMG WIRING
But otherwise it's true, the pros outweigh the cons if you're willing to spend the time getting it running right.
Bahaha, I hear you, everything's more expensive, even engine mounts! For a 5L you can get mounts for next to nothing!
Are you supposed to use full synthetic oil in these alloy pigs? :/ Crap... lol.
I'm kind of looking forward to doing the wiring side of things, don't mind it, a bit time consuming, but if you take your time it can make an engine bay - not seeing any/many wires wondering how its running/wired up. Especially since I have stumbled across a fairly detailed post on another forum, basically showing step by step how to modify a loom, just need the VZ's engine/computer wiring diagram, with numbered pinouts, and should be good as gold!
Now clear all that **** off the back of your tonner and get to work
Sir yes Sir! :rofl2:
I can see the benefits of the LS1, no doubt they're a good engine. However, i like to "try" and do different things and nearly every car i see now has an LS1, it just gets a bit boring that's all. In fact, i see the LS1 as todays EFI 5 litre conversion of 5-6 years ago, they used to be everywhere but now the LS1 has taken over. Now, i actually find it refreshing to see an EFI 5 litre in an early girl over the sea of LS1's.
However, like i've said before, my next car will have a carby SBC (i've actually stumbled across an LH sedan which will be my next project, but that's off topic).
Yeah I understand what you're saying completely, I was/used to be like that. But for a little while I've been trying to "walk in the many's footsteps."
Apparently its easier not to "re-design the wheel."
Although all I have is headaches and a lack of solid info, so looks like I'll be pioneering this build - with my apparent lack of "finding stuff on the interwebs" skills... Wasting time, and probably money along the way. :/
You wouldn't happen to know where a couple of detailed build ups of early Holdens with LSx's in them are, would you? Can't seem to find much around. And if I do its all contradicting info.
It seems 5-6 years ago they were the rage, and everybody was doing it. But now alot of them either didn't get finished, or their posts didn't get updated and the owners have perished and disapeared..!
Oh, and off topic is good, keeps the motarvation high hearing about other projects!
