Proper Jacking Locations
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by r_i_d_a_h, Aug 23, 2007.
  1. r_i_d_a_h
    r_i_d_a_h New Member
    '97 VS Commodore + '98 E36
    could some-1 show me a diagram of the underside of a VS of where i should propely jack it up from and where do i place the jackstands? i am using the hydraulic type car jack not the flimsy factory jack
  2. cxcxcxvcvcvc
    cxcxcxvcvcvc Active Member
    The Plains
    VT Commodore
    accordin to my vs calais factory manual there is two points on either side of the car to jack from and they can be located by the half circle cut out on the lower sill!
  3. vsiicalais
    vsiicalais Donating Member
    Wonthaggi
    MY15 VF SV6 Storm
    i have decided to upgrade my jack as well thinking it was a better option but found when i get a flat on the back the point on which i jack is no good as its too low. front is fine but i was thinking maybe the diff not too sure on this one either
  4. SweetWagon
    SweetWagon booosted
    Springwood NSW
    VS Berlina Wagon Supercharged
    Also is you want to jack the entire front end up ,the center of the crossmember. and to jack the whole rear end ,the diff.
  5. cruzn
    cruzn Member
    vr Commodore
    yep, what he said
