As the title says im after a diagram of the pulleys on the front of the engine and labelled which ones are which as i got a noise one and wanting to find out wat it is called so i can replace it... cheers
Easiest way would be to walk into your local parts supplier and they should have a diagram on their computer. From VS thread but they should be the same-
The ones labelled starting "EP" are the idler pulleys and part numbers for replacement "Nu-line" Brand.
